Originally Posted By: MysticGold04
So here's what I'm thinking...
I don't say this to be a jerk (though it may come across that way)...but if that's what makes you feel better, replacing the pump, then you should do it. After a casual glance at this thread, it appears that more than half of the suggestions are to leave it alone. That would be my suggestion, too.
However, there is a risk associated with not spending the money now. If you plan to keep this vehicle well into the future, you can probably plan on spending it at some point. And things like this somehow find a way of happening at the most inconvenient time. The water pump *should* give you enough warning of future failure, but I wager that they sometimes do not. If you spend the money now on a quality water pump (the Aisin pump will be a good pump), you can probably rest assured that you won't have to spend it again, and you can rest assured that you have removed most of the risk of continuing to drive with an older water pump.
There's also a risk with replacing the pump now. You will be replacing a pump that you know works with one that you don't know works. It's a new part, and from a good manufacturer, so it's probably good. Just recognize that there's risk both ways, no matter what you do.
It's whatever makes you most comfortable. Life is all about risk management, and some of is are tolerant of more risk than others. You can educate yourself about the potential of failure from boards such as this, but only you can make the decision on what is right for your family.
