A old friend of mine opened up an automotive shop. I have about 30,000 miles on my Nissan and figure I should do a ATF flush, and was always curious how the exchange machines worked so I brought in. About 8 liters of new ATF was put in the machine, tranny line was undone at the cooler, and the machine hooked up in line, started the car, and began the exchange process.
After the service was done I started to think though. The tranny oil pan was never drained before the service. So when the exchange process began, the fresh fluid going back into the tranny was being dumped back in a pan of old ATF and mixing with it. Upon further investigation and some phone calls around town, this seems to be how most places flush the tranny.
Also on a second note is it true that the fluid that goes through the valves gets dumped back in the oil pan without even reaching the cooler lines?
It seems like using an exchanger is not much more effective than doing a drain and fill a few times as the new fluid gets contaminated anyways?
