Pick my oil '75 Plymouth Gran Fury 400 big block
by gallydif
Today at 08:40 PM
Spark plug resistance R5 vs R6
by Ndx
Today at 08:39 PM
Firestone TF2876 C&P
by holdorf333
Today at 08:38 PM
Castrol High mileage or Valvoline Maxlife
by NH73
Today at 08:30 PM
Got to experience cornering ABS today
by LoneRanger
Today at 08:10 PM
Engine Heat Soak - What causes sluggishness
by ryan2022
Today at 08:03 PM
What product was that?
by another Todd
Today at 07:19 PM
choice between reciprocating corded saws
by edwardh1
Today at 07:04 PM
Is the driving experience getting worse?
by fdcg27
Today at 06:24 PM
Scratched wheel
by gabriel9766
Today at 05:52 PM
Gear oil added to motor oil in engine
by TiredTrucker
Today at 05:52 PM
Purolator 10111 Cut Open- Red Can- NEW
by FordBroncoVWJeta
Today at 05:51 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
109 registered (alanwayne1908, AMC, 69GTX, andyd, 2002 Maxima SE, 901Memphis, 8 invisible), 1701 Guests and 6 Spiders online.
58322 Members
66 Forums
251062 Topics
Page 4 of 21 < 1 2 3 4 5 6 ... 20 21 >
#3278039 - 02/11/14 01:00 PM Re: What does Liqui-Moly CERATEC do? [Re: a2gtinut]
demarpaint Offline
Loc: NY
Originally Posted By: a2gtinut
9300 is available but it is $50 to mix with 4-5 liters of engine oil. Need to call them and ask for it.
Good to know.
God Bless Our Troops
#3287428 - 02/19/14 04:38 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
Tron1 Offline
Loc: SACRAMENTO, CA USA
I put a can of Lubro Moly in the crankcase of my Venza last month. It is hard to determine, from the drivers seat, any performance enhansment. However, when is too much moly a bad thing? The quote for an internet site makes this statement...
"Also, molybdenum compounds in motor oils can degrade and
cause bearing corrosion and is particularly aggressive towards copper. In almost all cases, any engine oil
formula having "moly" will also contain a copper deactivator which will protect bearings from the moly
compounds. The only problem, the copper deactivator decomposes at relatively low temperatures and looses
it's potency after a few thousand miles, which can be seen in used oil analyses of moly rich oils having higher
than normal copper levels. Link Additionally, there is documentation in various SAE publications showing a
vast number of different species of moly friction modifiers, some providing better wear than fuel savings and
vice-versa, and unfortunately, there is no easy way to determine how a friction modified oil is formulated
other than to assume that a GF-4 or energy conserving oil is most likely to bias fuel savings for lower wear
protection . . ."
I would be interested in a discussion on the merits of the above quote.
1965 Shelby Superformance Cobra - Honda S2000 - 2014 Porsche Cayenne, Ford Crown Vic Police Inteceptor (donated)
#3287459 - 02/19/14 05:21 PM Re: What does Liqui-Moly CERATEC do? [Re: Tron1]
dave5358 Offline
Loc: North Bend
Originally Posted By: Tron1
I put a can of Lubro Moly in the crankcase of my Venza last month. It is hard to determine, from the drivers seat, any performance enhansment. However, when is too much moly a bad thing? The quote for an internet site makes this statement... "Also, molybdenum compounds in motor oils can degrade and
cause bearing corrosion and is particularly aggressive towards copper. In almost all cases... "
Just as a point of clarification, you are talking about Liqui-Moly Oil Additive product - the L-M MoS2 additive? This additive product was formerly known as L-M Anti Friction.
If you are referring to Liqui-Moly Ceratec, which was the subject of this thread, it does not appear to contain MoS2. The 'Liqui-Moly' part of this product's title is simply the company's current name.
If there's a moderator in the house, maybe he could make this a new thread.
2006 Forester XT
2008 Corolla LE
#3287559 - 02/19/14 06:50 PM Re: What does Liqui-Moly CERATEC do? [Re: dave5358]
Tron1 Offline
Thanks Dave for the info. I will attempt to repost in the appropriate thread.
Ron
#3287561 - 02/19/14 06:51 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
Clevy Offline
Loc: Saskatoon canada
Go to the website,or read the back of a can. It's explained simply and completely.....and it works as advertised
2006 Charger RT
Miles x 2 per oil filter
#3287580 - 02/19/14 07:06 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
147_Grain Offline
Loc: USA
Here's a few links:
Cera Tec
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_3721.html?Opendocument&land=DE
http://www.liqui-moly.de/liquimoly/mediendb.nsf/gfx2/3721%20Cera%20Tec_EN.pdf/$file/3721%20Cera%20Tec_EN.pdf
MoS2 Lubro Moly
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_1011.html?Opendocument&land=DE
http://www.youtube.com/watch?feature=player_embedded&v=qMJ1Fl1B77E
Additive Overview
http://www.liqui-moly.de/liquimoly/mediendb.nsf/gfx/2D2A7C2D3D0CCA42C12573DA00315AAF/$file/5616.pdf
#3288215 - 02/20/14 10:08 AM Re: What does Liqui-Moly CERATEC do? [Re: gus7]
Clevy Offline
Originally Posted By: gus7
graphite is BAD news for a lub ...it wear down like a lapping job and ceramics ....[censored] worst than graphite pour in sand !!!
You can expect to be taken seriously can you
2006 Charger RT
#3288510 - 02/20/14 02:17 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
MolaKule Offline
Loc: Iowegia - USA
Why would one add another borate when you already have something similar to this in fully formulated motor oils?
Borate Ester
Due to recent setbacks, my beach body will be postponed for another year. As usual, your patience is appreciated. smile
#3288648 - 02/20/14 04:31 PM Re: What does Liqui-Moly CERATEC do? [Re: MolaKule]
dailydriver Offline
Loc: Bucks County, Pa.
Borate Ester
^^^How do we know for sure that ALL fully formulated motor oils contain this already?? shrug
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3288677 - 02/20/14 05:04 PM Re: What does Liqui-Moly CERATEC do? [Re: dailydriver]
dave5358 Offline
Loc: North Bend
Borate Ester
Well, you could look here. Sadly, the use (or not) of boron is all over the landscape - 2ppm or less in Lucas, Royal Purple, Pennzoil Platinum, up to 245ppm or more in Mobile Super Synthetic, Kendall GT-1 and Shell Formula. If you're a Pennzoil fan but have to have your daily boron, then get Pennzoil Ultra (152ppm); Mobil-1 checks in at 108ppm.
2006 Forester XT
2008 Corolla LE
#3349460 - 04/21/14 07:31 PM Re: What does Liqui-Moly CERATEC do? [Re: TechnoLoGs]
Jteran5 Offline
Loc: NJ
I created an account here to ask a few questions on this product. Is liqui-moly ceratec OK to use with a magnetic drain plug? I am planning to change my oil soon and should I use this in conjuction with MOS2 when I do the oil change? Or should I just use ceratec and then on the next oil changes use MOS2 and use ceratec instead at every 30k miles? (Ceratec at every 30k miles and MOS2 every oil change?)
Edited by Jteran5 (04/21/14 07:32 PM)
'14 Subaru Impreza STI hatchback (Castrol 0w40 with '09+ Mazda RX8 Tokyo Roki oil filter )
#3349650 - 04/21/14 09:57 PM Re: What does Liqui-Moly CERATEC do? [Re: Jteran5]
dave5358 Offline
Loc: North Bend
No problem on magnetic drain plugs.
Why not stick with one product or the other and follow the label directions?
Both products - L-M Ceratec and L-M MoS2 Anti-Friction - have their followers and detractors. Ceratec provides wear protection by adding a ceramic coating to your engines friction surfaces. MoS2 fills in the pores of the metal. MoS2 has been in use for a much longer period and the industrial benefits of MoS2 are well known - automotive benefits less so. Ceratec is a new kid on the block, much more pricey and its benefits may last longer.
Big question: What are you trying to accomplish? If you have a specific goal you wish to accomplish (e.g. reduce oil consumption past the rings), then you may get a more meaningful response.
Please note that if this thread continues for any length of time, someone (who has never used either additive) will jump in and announce that you don't need either product. Strangely enough, they might be right if your engine is well ordered, gets regular oil changes, etc.
2006 Forester XT
2008 Corolla LE
#3349696 - 04/21/14 10:36 PM Re: What does Liqui-Moly CERATEC do? [Re: dave5358]
domer10 Offline
Loc: Ontario, Canada
Why does one need to have smoothing wrong to use a additive? This reasoning is getting old. I have nothing wrong, what I want to do is prevent less wear, and that what this is advertised to do. I like to take care of my things, nothing wrong with them, I am not trying to "solve" any problem, in fact I am trying to prevent problems.
I have used both extensively in all motorized applications, Im running mos2 in my bmw m3, after this run I am putting ceratec in it, I want to do a lab test before ceratec to see if it prevents a lot less wear. I run MoS2 every oil change after ceratec but this time wanted to do a before and after to see if I am actually preventing less wear.
2012 Dodge Ram Sport
2002 BMW M3
2008 BMW 135i
#3349721 - 04/21/14 11:05 PM Re: What does Liqui-Moly CERATEC do? [Re: dave5358]
Jteran5 Offline
Loc: NJ
I just picked up a 2014 Subaru Sti. I want to get the most life out of it. I want the best protection for the engine. I figured that ceratec was a good additive to use every 30k as instructed and that the MoS2 was a good additive to use every oil change.
Edited by Jteran5 (04/21/14 11:07 PM)
#3349758 - 04/22/14 12:13 AM Re: What does Liqui-Moly CERATEC do? [Re: Jteran5]
domer10 Offline
You are doing the right thing. Reduce friction, reduce wear.....and the pro's are endless.
2002 BMW M3
2008 BMW 135i
