well, i have an 02 Accord dx auto, when you drain the tranny, approximately 2.5 -3 qts of fluid is removed and the remaining 3-4 qts is left in the tranny. I want to do the cooler line technique, should drain the fluid first, connect the bolt, then take a long funnel , insert in the fill hole, disconnect the cooler line , have assistant have an open bottle of atf fluid open and ready for fill and another assistant observing the fluid from the cooler line into the container while the engine is running. Some suggestions please
