Thanks for the unnecessary reference to the meaning of Synchromesh, though I don't remember the function of a synchronized transmission ever coming into question in this thread.
What is in question, however, and we can debate this topic to no end, or just agree to disagree, is that "Synchromesh" refers to a specialized fluid that meets GM specification number 9985648, and Chrysler MS-9224. Synchromesh fluid is very different from GL-4 rated gear oils, ATF and other fluids that are safe for use in synchronized transmissions.
The history of the Synchromesh fluid, and the meaning or function of a "synchromesh" transmission are both moot points. Nobody called a transmission lube "Synchromesh" until that specific fluid was brought to the market, despite synchronized transmissions being around long before that time. If the word synchromesh has become used to describe any synchro-safe transmission fluid, it's only because people erroneously diluted that word, not aware that Synchromesh is a specific type of fluid.
Quote:
All fluids for use in a synchronized manual transmission can be properly called synchromesh fluids.
To each their own. I could call every bottle of motor oil on the planet "Heavy Duty Engine Oil" because I perceive modern oil's robustness as heavy duty. That doesn't make me correct, and my opinion at the end of the day is exactly that; an opinion! I'd just be adding confusion to something that has too much to begin with.
Quote:
Parts counter people have never been known to be Historians of, or even remotely experts in Lubrication.
The same can be said for those who mix transmission lubes in their garage and resell it on the internet.
Don't just use my parts counter people as an example. Type Synchromesh into your favorite search engine, then click "shopping" to see results. You'll get Synchromesh fluid and little else. How many examples do I need to give? They are endless.
