Originally Posted By: Bror Jace
I am not sure this is the case. Also, be sure to watch your capitalization … especially on this topic. “Syncromesh” would imply a particular brand (perhaps like GM, Chrysler or Pennzoil) … while syncromesh (especially as I used it) would refer to an entire class of fluids designed to be used with synchronized manual transmissions.
I've argued this before, and I'll argue it again. Synchromesh, while not a particular "brand" is a unique fluid that is not all-encompassing of MTFs designed for use in synchronized transmissions.
The Synchromesh name came out when that particular GM/Chrysler fluid requirement was established, and the fluids of the same name were introduced. MTFs which were designed for synchronized trannies existed before then, and afterwards. They did not just arbitrarily take the name of that specialized fluid, Synchromesh. You guys can choose to use it in that sense, to each their own.
Go to your local auto parts store, and ask for a quart or liter of Synchromesh, and see what they come back with. They'll likely either hand you a bottle of Pennzoil Synchromesh or tell you they don't have it, even though they have dozens of bottles of appropriate gear oil that would work fine in a Synchronized transmission.
In short:
Synchromesh = Synchromesh
Manual Transmission Fluid safe for synchros = MTF, *not* Synchromesh (two completely different animals)
IMO, people have just gotten lazy, and since Synchromesh availability & popularity has declined (modern transmissions no longer list it as a requirement), it's been easy to associate synchro-safe fluids with that name.
