Does this tail pipe pic tell you anything?
by LeakySeals
15 minutes 20 seconds ago
Security Camera system
by Alfred_B
43 minutes 7 seconds ago
Valvoline is going to be listed on the NYSE
by demarpaint
Today at 03:46 PM
Rislone or stp ethanol fuel treatment
by Indiana79
Today at 03:17 PM
Super Tech #3614 CUT OPEN
by car51
Today at 03:03 PM
Flight Tracker
by Eddie
Today at 02:33 PM
Art and ugly are separated by a fine line
by HTSS_TR
Today at 02:27 PM
2013 Ram 1500 Vibration Issue
by 757guy
Today at 11:21 AM
Speed & Temperature ratings vs cold PSI
by badtlc
Today at 10:52 AM
Worthy of a news story??
by andrewg
Today at 10:13 AM
Gorilla Shooting...decaying moral values?
by Smokescreen
Today at 09:53 AM
Oil Change Frequency - 04 Neon
by racer12306
Today at 09:15 AM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
81 registered (Branson304, bbhero, Atesz792, bdcardinal, Alfred_B, BeerCan, 11 invisible), 1986 Guests and 326 Spiders online.
58031 Members
66 Forums
249634 Topics
Page 2 of 2 < 1 2
#2989905 - 04/30/13 10:44 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
ChiTDI Offline
Loc: Chicago IL
Ah, didn't know.
50k on a 2002, you got a plum!
I put 165k on mine before passing to the next generation in the family. Good luck with yours!
#2990656 - 05/01/13 07:21 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: ChiTDI]
FXjohn Offline
Loc: NE Indiana
Originally Posted By: ChiTDI
Ah, didn't know.
just taking care of it for an older family member. I'm going to get new tires, new coolant, cabin filter, trans fluid, power steering fluid.
it's never seen salt!
#2992264 - 05/03/13 01:21 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
ChiTDI Offline
Loc: Chicago IL
You might have two drain plugs for the ATF/differential. Mine did.
Yes, ATF for the FWD differential, and it was a common fill from the dipstick. Drains were separate, so just an FYI.
Diff plug was on the front of the housing, and allowed another quart to drain.
#2992459 - 05/03/13 05:24 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: ChiTDI]
FXjohn Offline
Loc: NE Indiana
I'm gonna have it done at the dealer, but that's the only thing left to do now. Unless I forgot something. I did double check, it has 62k on it.
I can't believe how sucky the positive terminal is. especially compared to side terminals.
#2993837 - 05/05/13 02:19 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
ChiTDI Offline
Loc: Chicago IL
Yeah, mickey mouse clamp if I remember right.
I'd have the dealer change the PCV valve too, if it was me. They only cost a finn, but those 1MZ-FE engines can get sludge if they are ignored.
62k - Probably run another 10 years easy.
#2994088 - 05/05/13 07:54 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: ChiTDI]
FXjohn Offline
Loc: NE Indiana
thanks I'll have that done too. this is the xls with the lexus motor. compared to my truck this thing is a sports car. it sets you back in your seat.
#2999942 - 05/12/13 01:45 PM Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn]
The Critic Offline
Loc: Walnut Creek, CA
If it still has the original timing belt and water pump, I would use this opportunity to have a complete timing belt job done due to age.
And when the water pump is done, the coolant will also be done.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
Page 2 of 2 < 1 2
