CHEVRON DELO Reveals their line up of CK-4/FA-4
by Powerstroke
08/27/16 03:07 PM
New belt or new belt tensioner?
by Parlay_Slow
08/27/16 02:53 PM
PP 5w-30 Amazon subscribe and save
by buck91
08/27/16 01:52 PM
My parents took my nissan s13 silvia
by Nissan101
08/27/16 01:21 PM
New Hyundia Santa Cruz pickup with extendable bed
by gfh77665
08/27/16 01:12 PM
Pro Line PPL 14610 4,000 miles CUT OPEN
by car51
08/27/16 01:00 PM
STP S-10590 6,000 miles CUT OPEN
by car51
08/27/16 12:47 PM
Store Kerosense in Non-Vented Container?
by ET16
08/27/16 12:16 PM
Opinion on Salvage Title
by DBMaster
08/27/16 12:14 PM
Different labels for 303 protectant
by 007
08/27/16 12:07 PM
cstoremotoroil.com
by AirgunSavant
08/27/16 09:37 AM
What's good/bad about a 2006 Mazda 5?
by 55Test
08/27/16 09:30 AM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
68 registered (albertdi, 2009Edge, amusing, AandPDan, alanwayne1908, 4WD, 4 invisible), 1736 Guests and 38 Spiders online.
58935 Members
66 Forums
253630 Topics
Page 1 of 3 1 2 3 >
#2956108 - 03/30/13 02:27 AM 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m
Oneill5491 Offline
Loc: Portland, OR
Here's my fourth UOA on my 2010 Buick LaCrosse CXS. Sorry I was remiss in posting this UOA for a sample I took over a month ago.
Results for this UOA are on the left side and the results from prior UOAs follow on the right. Please note that the prior UOA performed was on the current oil change back at around 50% OLM and this current UOA was done when the OLM hit 2%.
Engine Model: GM LLT 3.6L V6 Direct Injected
Oil: Pennzoil Platinum 5w-30 Synthetic
Oil Filter: Purolator PureONE PL12222
Miles on Oil: 10,569
Miles on Engine: 42,067
So looks like we got a bit of a surprise with this UOA revealing that the oil contained unwanted high levels of water. Really don't know how that happened, but I'm certainly looking forward to the next UOA to see if this is a trending problem. Anyone have ideas on how this can happen?
Aside from that, it doesn't seem like this brand of oil garnered better results in lowering wear metal contamination. So for this time around, I just used the oil I happened to have a case of in my garage which was Mobil 1 (the non EP flavor this time).
As usual, I appreciate any feedback and advice you all have to give.
#2956122 - 03/30/13 04:33 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: Oneill5491]
Clevy Offline
Loc: Saskatoon canada
Wow. Those are some really high iron numbers. I see you are running roughly 10000 mile drains and it seems both brands didn't do much to help the iron number.
I wonder if maybe an oil with a high moly content would help. Or perhaps try a conventional at half the mileage and see if the iron numbers settle down.
With iron numbers that high I almost expect this engine to dissolve(joking).
Is this common for this particular engine to shed metal like that or do you have a problem.
I'd certainly try something else since neither of these products have done much to lower the iron.
Thanks for posting.
2006 Charger RT
Miles x 2 per oil filter
#2956152 - 03/30/13 06:31 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: Oneill5491]
chubbs1 Offline
Loc: Merritt Island FL, USA
Those numbers have held pretty steady so I would assume it is normal for your engine.
I personally like to search for the "best" oil for my vehicles and have always had good luck with M1 0w40 in ANY engine that calls for 5w30. Not a huge dif but may help with wear.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2956187 - 03/30/13 07:22 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: Oneill5491]
salv Offline
Loc: Cadyville, NY
Shorten your oil change interval to 7500. No need to find a different oil.
2003 Trailblazer: Mobil Super HM 5w30 L25288
2000 Ford Focus Wagon: Mobil Super 5000 DW-5230
#2956214 - 03/30/13 07:47 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: Oneill5491]
Markzip Offline
Loc: Northern Wisconsin
Change the filter at 3000 miles or install the Fram Ultra or Mobil One or Bosch distance. The filter you are using is only rated for 3ooo miles according to over the phone with Puralator. Good filter just not rated for the mileage and see what happens to the numbers. Why would you not change a filter or buy a inexpensive one with a $30,000 car and high Syn. oil? Maybe you didn't know but the filters are as important as the oil. and the value of the car. The moisture is not a surprise with where you live.
Edited by Markzip (03/30/13 07:47 AM)
18 engines all need fixing.
Buick Lacrosse 2005
Buick Park Ave 1993
Buick Park Ave 1996
Toyota Previa 1995
Chevy G-30 diesel 1983
J.Deere 2020 Gas 1969
#2956227 - 03/30/13 08:03 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: Markzip]
volk06 Offline
Loc: Iowa
Wrong. The P1 is good for 3000 OR the specified OEM oci. The filter is not going make that much a difference in regards to wear metals, especially since most of the long distance filters have a lower efficiency rating.
Anyway I suspect the water content has something to do with the fuel dilution, since they didn't test for that and this engine is known for fuel dilution.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#2956251 - 03/30/13 08:21 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: Markzip]
BlueOvalFitter Offline
Loc: Cajun Country, La.
You would have a field day with the members in the OIL FILTER FORUM. A lot of them are H E L L bent on using the same oil filter for more than (1) OCI, and some, even more!
2007 F150 XL, 4.2 V6, 4R75E Transmission
Pennzoil Platinum HM 5W30, M1-209 Oil Filter
"One Filter, One OCI!"
USA
#2956283 - 03/30/13 08:54 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: BlueOvalFitter]
JavierG Offline
Loc: Fresno, CA
Are you saying that they shouldn't follow the car manufacturers recommendation? I'm reading my owner's manual and it says to change every other OC. boxing
2007 Honda Ridgeline RTX - 1057 mi - Pennzoil Ultra 5W-20, K&N filter
1995 Acura Legend LS Coupe - 167mi - NextGen Maxlife 5W-30, Champ filter
#2956290 - 03/30/13 09:00 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: JavierG]
"THEY" can. But nowhere in my manual does it read like that. That, along with common sense and knowing an oil filter is like cheap insurance, will prevent "ME" from using one for more than one OCI! hornets
USA
#2956322 - 03/30/13 09:25 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: BlueOvalFitter]
JavierG Offline
Loc: Fresno, CA
So YOU should stop criticizing THEM since THEY are not forcing YOU to follow THEIR routine. spank
Oneill, the LaCrosse is probably my favorite Buick. Nice looking car inside and out.
Edited by JavierG (03/30/13 09:28 AM)
#2956326 - 03/30/13 09:30 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: JavierG]
And, YOU should let me act as a member here and voice MY opinion like other members are entitled to, and not worry about it! USA
USA
#2956349 - 03/30/13 09:47 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: BlueOvalFitter]
JavierG Offline
Loc: Fresno, CA
But YOU are not merely offering an opinion. YOU are criticizing others for THEIR opinion. USA Canada OT
#2956367 - 03/30/13 09:57 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: JavierG]
If you go to the OIL FILTER FORUM you will see my OPINIONS there also. And, as I stated there, I will state here; TO EACH HIS OWN! Until it is proven in a lab by scientist', oil gurus, etc. I will continue to use an oil filter only once! And, I will voice my OPINION, even if YOU CLAIM it's CRITICIZING them, (only your opinion) any way I choose to.
Does it bother you the way I voice my OPINION? If you must know, I am disabled and must sit down 98% of the day. So, with that time I read a lot on my computer, which in turn means I can hash out this conversation with you FOREVER! USA
USA
#2956389 - 03/30/13 10:15 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: BlueOvalFitter]
Bill in Utah Offline
Loc: UT
No actually you will not.
This is the UOA section on the board and you have stated your part as has the other member
So since it is off topic I'm sure both of you are done with the off subject comments OVER AND OVER.
Thanks, Bill
#2956391 - 03/30/13 10:17 AM Re: 2010 Buick LaCrosse - Penz Platinum 5w30 - 10,569m [Re: Bill in Utah]
Thanks, Bill
Sorry Bill. smile
USA
Page 1 of 3 1 2 3 >
