I'm working on a 97 Nissan D21 pickup with the 2.4 (side job) - replacing the timing chain and guides among other things... I've noticed that on this truck and another like it that I see regularly at the shop I work at, if you let it sit for a few hours, then start it, it will rattle to beat the band. It is timing chain rattle from a malfunctioning ADBV. It is confirmed by removing the filter after an extended sit and not getting any oil coming back out. The truck I'm working on and the shop customer's truck both have Wix/NAPA Gold 51361/1361 filters.
For my side job customer, I'd like to stop the start up rattle and any damage to the guides if possible. My first thought was the OEM 1520855Y00 filter, but after a call to the local dealer, none are stocked due to low sales. I'd have to order a case of 48... No thanks.
So now what? It has to be locally available. Pure Ones are found in the next town over (15 miles away). Classics can be found here, but I'm not to sure about their nitrile ADBV. Otherwise it's Wix and Wix variants which don't seem to work, Frams, M1's, Bosch Distance Plus, AC Delco, Motorcraft, Mopar and K&N's.
Also, is there another Nissan filter app that would work in place of the 1520855Y00?
