Can't figure out how to get the full UOA on here but here are the comments from Blackstone.
Copy Paste info is scattered all over the place?
DAN: Nothing problematic was found in this sample. Universal averages show how metals should read after
about 8,200 km on the oil. You're already running longer, but you're still getting better-than-average wear in
most cases. Lead was a touch higher than average, but a mere 2 ppm isn't anything worth losing sleep over.
There was no contamination like coolant, water, fuel, or excessive dirt present in the sample, and both the
viscosity and the TBN (which measured 3.1) held up nicely. You shouldn't have any problems with a 12,000
km run next time.
1989 Olds 98 3.8L 380,000 km. 10,000km oil change interval. using cheap Napa oil filter
Just an FYI Formula 1 oil goes on sale at CTC every year before Christmas for $19.99 a 5 quart jug.
I bought 15 jugs to stock up.
