I don't see many truck engines, mostly car turbo diesels and the only ones with carbon deposits are those from inner city use, taxis in particular. The solution is a better oil and in some cases a fuel additive, although you don't really need fuel additives if your fuel quality is good. The direct use injection cleaners are used sometimes by the taxi folks prior to an emissions test in particular.
I have seen a few coked cylinders caused by worn fuel injectors, but because most folks don't drive around with a smoker for very long before the Police stop them, those cases are very rare.
Liqui Moly are my local company and although they also produce an oil scourer additive, they are at least including a warning that it is not to be used for severe sludge cases, the oil pump feed screen should be checked first and high RPM use should be avoided. The same warning should be added to any of the drive around snake oils.
