I've searched and read and quite frankly am seeing oil cans in my sleep!
I could use some direction with regard to selecting an oil for my 1991 Isuzu Trooper with 175K miles. This is not a daily driver but is used for weekend trips, periodically hauling a small trailer with loads of gravel, dirt, and the like, or for errands on weekends and for commuting in snow storms. So, a mix of long and short trips but used intermittently. I probably put about 1500 - 2000 miles a year on the vehicle.
I go through about a quart every 1500 - 2000 miles and it has done so for years. There is no blue smoke on start up -- no overt signs whatsoever of burning though I think that's where it goes. There are minor leaks at the valve covers. The rear main seal was replaced with the clutch about 30K ago -- no leaks there. I've used Chevron 10w30 mineral oil for years, changing frequently (at least 3k or so miles) over the last 15 years. It's gotten me this far.
So what oil should I be using with the goal of staving-off rebuild/replacement and getting the very most out of this engine? I'm afraid that synthetic will be money wasted given the infrequency with which I use the truck. Not sure that a high mileage oil is necessary as I'm not trying to stop leaks. Increased mpg would be a great byproduct but, hey, it is a truck! I live in the Pacific Northwest so in summer, 80's is norm, 90's is hot and uncommon. In winter, 30's and 40's common, 20's uncommon and dropping to the teens is rare.
Hope I didn't forget anything! Thanks up front!
Eric
Eric
