Originally Posted By: meep
I have done the water trick for years--- dad taught me how back in the early 80s.
I think it's probably just as effective as seafoam down the gullet.
BUT-- with DBW throttles I'm not sure how to do it---- because you can't pour with the right, and gas it with the left on the throttle plate, to keep it running. you'd have to use small, small quantities of [liquid of choice] to keep from stalling.
I was working on a system to test on my Tacoma to later use on a Land Rover.
(two bottles of water worked much better than the initial two cans of seafoam and solved a very NASTY rough idle on the Rover.
I was planning on one of my usual 700+ miles trips with this just to see what happened.
Besides keeping things cool...
I would t-tap into a vacuum line, run a line from the T into the cab. Use a self tapping valve to control water flow into the vacuum line from the 5 gallon Poland Spring cooler bottle so I could fine-tune the amount being delivered. It would be easier with two of me to drive and control the valve based on RPM's.
Sort or like the Ampco/MMO oilers, but with water and a dose of MMO for lube/rust.
A cheaper version of this
http://www.summitracing.com/search/part-type/water-injection-systems Had all the parts for about $12. Never got around to it though.
