Hi, I have a 08 Rx350 with 152K trouble free miles. All I have changed are filters, fluids, spark plugs, v-belt and struts. The only issue is once in a while lets say 6 times a year, I will get what's called a "transmission flare" where the RPM revs up 750-1000 (lasting 2 seconds) more than the usual gear shift between 3rd and 4th. I went to get some coolant yesterday and the parts guy told me that Toyota changed their policy and now recommend changing the Toyota WS at every 100K.
Is this true? Should I go ahead and change it at the dealer? The dealer wanted 250 for drain and fill.
A search of this issue on the internet basically came out inconclusive. It seems like most people do not ever change it since it's considered lifetime and it's not a DIY project.
If anyone has some insight it would be appreciated. I have newer Toyotas (10 sequoia, 12 higlander, 12 camry) with the WS and if it seems like people are changing it earlier, perhaps that is the way I'll go.
Thanks in advance.
Thanks in advance.
