Did you read my PM's?? You must have a Tech 2 (which you CANNOT get for $335..add another $1200 or so) or suitable aftermarket TPMS tool like in the links I sent you.
You started another thread when I already gave you the answer in your other post, lol.
But I did pull the 2009 data:
Service Information
2009 Pontiac Vibe - FWD | Vibe VIN S Service Manual | Document ID: 2504877
#10-03-16-001: TPMS System Service and Re-Learning Sensor IDs - (Jul 19, 2010)
Subject: TPMS System Service and Re-Learning Sensor IDs
Models: 2011 and Prior GM Passenger Cars and Light Duty Trucks
2010 and Prior HUMMER H2
2009 and Prior HUMMER H3
2010 and Prior Saturn Models
2009 and Prior Saab 9-7X
with Wheel-Mounted Tire Pressure Sensors
In the event that the spare tire, which is normally not equipped with a tire pressure monitor (TPM) sensor, is installed in place of one of the road tires and the vehicle is driven above 40 km/h (25 mph) for 20 minutes or more, the TPM indicator icon on the instrument panel cluster (IPC) will flash for approximately one minute and then remain on steady each time the ignition is turned ON, indicating a diagnostic trouble code (DTC) has been set.
The driver information center (DIC), if equipped, will also display a SERVICE TIRE MONITOR type message. When the road tire is repaired and reinstalled in the original location, the TPM indicator icon illumination and DIC message may remain displayed until the DTC is cleared.
To ensure that the TPM indicator and the DIC message are cleared after service, it is necessary to clear any TPM DTCs using a scan tool. If a scan tool is unavailable, performing the TPM relearn procedure using a TPM diagnostic tool will provide the same results.
It is advised to perform the relearn procedure away from other vehicles to prevent picking up a stray sensor signal. If one or more of the TPM sensors are missing or damaged and have been replaced, then the relearn procedure must be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2012 General Motors. All rights reserved.
