Hi again everyone,
Perhaps another non-issue here, but I wanted to run it by just in case. Yesterday I ended up servicing the rear axle by myself for the first time ever as I'm constantly trying to learn the do-it-yourself techniques.
I ended up overfilling it a bit, as I later found out the capacity is 3.75 pints (or 1.875 quarts). Thinking that you fill it to the bottom of the fill hole (Ford manual said to fill it between 1/4" to 9/16" below the bottom of the hole), I actually put 2.5 quarts (5 pints) in.
So it's overfilled by about 5/8th of a quart at the most. With my oversight, should I go back and remove the excess? Thanks again everyone.
