2002 GMC Yukon Climate Control Problems
by Kgrant
02/06/16 01:11 AM
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
02/06/16 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
02/05/16 11:08 PM
GM Oil Life Update
by CapitalTruck
02/05/16 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
02/05/16 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
02/05/16 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
02/05/16 08:48 PM
why would someone want to pay with a phone?
by turtlevette
02/05/16 08:16 PM
The connection was reset problem
by Triple_Se7en
02/05/16 08:14 PM
BIG PROBLEM!
by Avery4
02/05/16 08:03 PM
11,000 miles on a BMW
by BigJohn
02/05/16 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
02/05/16 07:20 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
42 registered (AutoCoil, asand1, bbhero, akela, AJP, 4 invisible), 613 Guests and 204 Spiders online.
56834 Members
66 Forums
244295 Topics
Page 3 of 3 < 1 2 3
#2795154 - 11/06/12 10:08 PM Re: Generator failures [Re: Donald]
ron917 Offline
Loc: New Jersey
Make sure that you can actually siphon gas from your vehicles before you really need to. My Outback and Montana have things that block a hose from reaching the gas tank through the filler neck. The hose goes in pretty far, a couple of feet, but something blocks it. I don't know if they are anti-theft devices, emission control stuff or just the way they are built. I haven't tried siphoning from either of the Hondas yet.
Edited by ron917 (11/06/12 10:09 PM)
2007 Subaru Outback 2.5i
2003 Pontiac Montana
2011 Honda Fit
2006 Honda Accord
1990 Mazda Miata
#2795930 - 11/07/12 07:03 PM Re: Generator failures [Re: Donald]
live_to_hunt Offline
Loc: New Jersey
My Briggs and Stratton Storm Responder from Home Depot lasted 2 tanks of gas. The engine ran fine the brushes went so it did not make any electricity. I just got it back today My town has been out of power for 8 days.
2010 Tundra
2001 Harley Heritage Softail Classic
#2796722 - 11/08/12 02:10 PM Re: Generator failures [Re: gd9704]
lexus114 Offline
Loc: Easton, PA
Originally Posted By: gd9704
My beloved Honda EU6500is is currently on loan to a friend who's been without power for 5 days. I'm only a little uneasy about that. I feel better knowing it got a fresh crankcase of Mobil 1 0w-40 before I dropped it off to them. I'm keeping track of the hours it's run since then (running since 7pm last night).....the manual calls for 100 hour oil changes. If we get that close I'll run to their house to change it--they are mechanically clueless.
They call for 10W-30??
2012 Mercedes-Benz C300 4matic
2015 Lexus RX350 AWD
#2796918 - 11/08/12 05:31 PM Re: Generator failures [Re: lexus114]
chefwong Offline
Loc: New York
Tachmeter/Hour Meter is your best friend. That was the 1st thing I installed on my new Gennys - before I even put in oil
#2797550 - 11/09/12 10:36 AM Re: Generator failures [Re: Donald]
HerrStig Offline
Loc: Boston, MA
If you're clever you can use the fuel pump in your car to pump gas into a can for the generator. I will say no more, though, because you really DO have to know what you are doing.
Edited by HerrStig (11/09/12 10:37 AM)
#2798110 - 11/09/12 08:49 PM Re: Generator failures [Re: ron917]
cjcride Offline
Loc: Ontario Canada
Same for our 2003 Toyota Echo. A mechanic pal said it is probably a rollover valve designed to stop the fuel from flowing out the filler neck if the car flips.
#2798998 - 11/11/12 07:42 AM Re: Generator failures [Re: Donald]
repairman54 Offline
Loc: Montague, NJ
10 days straight on my 10hp briggs powered 5.6k craftsman gen set for Sandy.
Only off to fuel & check oil in those 10 days.
10-30w ST synth. oil since it's birth. It used aprox. 2 oz. in that 10 day run.
Ran 5 straight days last year for Irene with no adding oil.
Oil changed, marine fuel stabilizer in the gas and sleeping in the garage ready for the next outage. Tank is fully fueled BTW and gets changed out yearly if not run.
Unit is 5 yr old now.
John
Anything you say can & will be misquoted & used against you
'07 Mustang GT 3 pedals
FLHR
Doo 1200 GSX
Doo 600 SDI
Poo XC700
Sea Doo GSX
#2800112 - 11/12/12 10:53 AM Re: Generator failures [Re: Donald]
ChrisJH Offline
Loc: CT
Ridgid 8000W generator, only seen Pennzoil Plat 5W-30 since day 1.
Changed every 25 hours (manual says first change is at 25, then every 50 after that but I dont mind doing it every 25). The remote control panel with LCD readout kicks butt because there is an hour meter on it.
Started it up the Thurs before Sandy just to make sure it works. Fired right up, ran fine.
We didnt lose power until the Friday AFTER the storm, they had to cut power to work on lines in our area. Generator got us through a cold Friday night, power was back the next day.
Subaru EX 40 engine....once the unit is out of warranty Ill get a tri-fuel kit for it. No NG hookup available for me, but Ill use propane if I have to.
Edited by ChrisJH (11/12/12 10:53 AM)
#2800114 - 11/12/12 10:54 AM Re: Generator failures [Re: repairman54]
lexus114 Offline
Loc: Easton, PA
I remember when I was a kid and my Dad and I belonged to this group of Deer hunters. We had a cabin up in Long Pond,PA. Anyway, the one member had a 8hp B&S Generator so we could watch TV. I remember going outside for something, and all I saw was this Red glowing muffler on that thing. Looked pretty cool in the total darkness. tongue2
Page 3 of 3 < 1 2 3
