Z zr900 Joined Apr 4, 2011 Messages 41 Location MI Nov 8, 2012 #1 What tranny does a 97 Chrysler Sebring jxi with the 2.5 V6 have? What is a good choice for fluid for this vehicle?
9 95busa Joined Oct 15, 2005 Messages 1,250 Location Tennessee Nov 8, 2012 #2 It was probably originally specced for ATF+3 or 7176. Everything was back specced to ATF+4, which is backward compatible. I ran it in a 1990 Ram 1500. Bottom line- cant go wrong with ATF+4.
Donald Joined Mar 21, 2004 Messages 29,645 Location Near the beach in Delaware Nov 8, 2012 #3 I would see if the ST ATF does that spec and if so I would use it. It is a 15 year old vehicle.
B Bgallagher Joined Apr 17, 2012 Messages 3,159 Location Boston, MA Nov 8, 2012 #4 Originally Posted By: Donald I would see if the ST ATF does that spec and if so I would use it. It is a 15 year old vehicle. +1 I believe ST makes an ATF +4. With the strict guidlines used to make +4 I would use the ST with confidence.
S SuperDave456 Joined Oct 29, 2008 Messages 2,500 Location Dallas, Texas Nov 8, 2012 #5 Super Tech ATF+4 all the way. I've used it in several vehicles and have had Zero Problems. Even used it in a old school bus awhile back.
N NHGUY Joined Oct 9, 2011 Messages 5,090 Location USA Nov 8, 2012 #6 Must be the "good old" 41TE. Only use +4 and no additives.Very dainty/finicky trans.
T Texan4Life Joined Jan 29, 2010 Messages 2,264 Location Texas Nov 8, 2012 #7 we use supertech ATF +4 (has to be +4) in our 97 caravan.
