2001 Ford Ranger 2.5L 165k miles. I want to keep the truck for awhile since I hear they last. Is my method ok or should I just get an oil change... My method:
Put Penzoil Platinum Synthetic or Mobile 1 High Mileage Synthetic (both are 5w30) in and use a good filter (usually Mobile 1, K&N or whatever is from the $25 to $30 oil+filter special) and then run the truck for about 4500 miles. At that point, I'm usually down anywhere between .5 to 1 quart. I get a new bottle of the oil I used, and then add between .5 and 1 quart (however much it's down), and then run it another 2000 to 3000 miles or until it's down about a quart again.
Or should I just get an oil change at 4500 miles when I'm usually down a little bit?
Never did an oil analysis.
