Have you ever though about making your own wildcat cartridge?
The other day I was thinking about making a 9/45. It would use a 45 magnum case shortened a little and necked down to 9mm. I looked around and found that someone had already done something similar. It is the .38 Casull. There is also one called the .38/.45 Clerke.
Sometimes I come up with other cartridges; mostly to save lead.
22/9 - a 9mm necked down to .22
22/38 super - a 38 super necked down to .22
22/40 - a 40 S&W necked down to .22
30/40 - a 40 S&W necked down to .310, and would use .32 cal bullets or light .30 cal bullets.
40-30 - a 30-30 sized up to fit a .40 cal bullet. Might need to be sized to .390 though.
22 Carbine - 30 Carbine necked down to .22
41-08 - a 308 Winchester cartridge sized up to fit a .41 bullet
I though about shortening the .223 Remington, but Remington already did that with their .221 Fireball.
