Hey all,
I'm finally getting around to going through the brakes on Ol' Yellar. We're starting with the rear, but already I've run into unfamiliar territory.
The axle I believe is the Dana 60. When I pulled off the rear drum, it comes in one piece(drum,hub, studs). However, the drum is sold with only the drum part, not the hub or studs. I don't have much experience with brakes like these.
The drums should be replaced IMO, they are likely too far gone to turn. Do the studs have to be tapped out? I'm not sure what to do here.
Thanks.
Thanks.
