Originally Posted By: AVB
There are several different systems, some use a machine like the MotorVac system, some use a small pressure tank.
Either way can be effective, the only true way to know if they need cleaning is to do a balance test or to have them bench tested. Either test is likely to cost just as much as cleaning so it is cheaper just to get them cleaned instead of tested then cleaned.
So at the end of the day, you think its needed? Im looking at the symptoms of dirty fuel injectors and im not experiencing any of these riht now.
