We're having problems with our motorhome. Its a 1989 Pace Arrow on a Ford F53 chassis with the 460. It was running fine until my father swapped the engine battery on it. Now the fuel pump is not getting power. I have not been able to find any fuses, or fuse links that are bad. The problem is the green fuel pump relay is not getting 12v switched power. I can jump power from the battery to the relay and the fuel pump will come on. I have traced the red 12v switched wire back to the computer and the wire is good. Like I said the motorhome ran fine before swapping batteries, so I'm assuming there was an arc that cooked something. Could the computer be dead? I also cannot get the computer to go into test mode with my OBD I scanner. Thoughts?
