Well, As a ASE Mastertech in Auto and MD/Heavy trucks I can tell you there is no such thing as a cure all "mechanic in a can". I would have suggested doing a real flush with BG chemical kits rather than part 1 of the three chemical kit. 44k seems to work better as a follow up, preventive measure, or clean up for a small problem rather than a fix all for an existing condition,although I have seen it open stuck injectors after running in the tank 5 times normal strength and letting the truck sit for a weekend.
Not diagnosing it anything is possible.
