I guess this should go in this forum. A friend of mine has a larger fishing boat. It has a 350 Chevy engine in it. The Alternator is not your standard GM Alternator. It has an externally mounted voltage regulator that also holds the brushes.
It's a marine type with screens to prevent an explosion and what ever else they require for marine use.
The thing overcharges the battery......17+volts which burns up the electric fuel pump and light bulbs.
We replaced the Voltage Regulater with a new one and it still does it. Cleaned grounds etc.
It has a wire that I assume tells the regulater what the voltage is.I ran that straight to the battery. Still overcharges. I also ran a new ground wire from the Alternator to the battery and it still overcharges.
The Alternator tests fine on the bench. Any ideas? We want to go fishing.
PS: It's an Aquasport 215 with a Volvo Penta outdrive.
