Some fuel additives residuals( small amounts of chemical that end up in the crankcase oil) seem to react with the softer metals in a motor and show higher values. Whether this is a cleaning effect or wear is something an analyst will have to determine knowing the engine,oil, and trends.
Generally speaking if the soft metals remain below 20-50 ppm depending on the engine then it is not harmful. Disclaimer; rules of thumb in oil analysis are problematic because of variability. BE CAREFUL relying on them.
Every one of the fuels adds on the market are different and knowing exactly which chemistry they are composed of is impossible.
I have NOT seen increased wear with Techron, Nuetra, Fuel Power, Redline, Amsoil PI, TK-7 in engines that are mechanically sound.
for wtd I would have to study your total results and consult with you to find an answer. My guess is the engine is not as healthy as you think. Leaky injector etc.
Terry
[ January 17, 2003, 09:15 AM: Message edited by: Terry ]
