So far I haven't found a solid answer in all of my searching, so I figured I'd quit lurking and post.
My wife's car is a new-to-her '06 300C SRT8 with ~33K miles on it. The previous owner says the oil was last changed around 29K, so there's a couple more K left before the next oil change.
The no-brainer would be to follow the factory recommendation of 0W40 every 6K miles, but I'm one of those people who thinks that maybe the road less traveled could be better--I'd like to go more than a 6K OCI without compromising protection. (My wife's previous car was a 5.7L 300C and I pushed it to 10k-11k OCIs running Mobil1 EP with good results, adding about 1 quart around 7K.)
Most of the UOAs I've seen for Mobil1 0W40 show that it shears down to a (high) 30-weight after 4K-5K miles or so. That makes me a little hesitant to try to push it beyond the Chrysler-recommended 6K miles. The Mobil1 TDT 5W40 claims it is more shear-stable and has a higher TBN, so it would seem to be a better candidate for an extended OCI in my wife's SRT8 and it also boasts excellent wear protection. (Winters are generally mild--it rarely gets very far into the 20s at night and the car is garaged, so cold starts in the morning are usually above freezing. IE I don't foresee any cold start wear issues with 5W40 as opposed to 10W40.)
I've seen more than a few comments about TDT 5W40 being used in SRT8s with positive results, but have yet to actually see any of those results, much less with UOAs comparing 0W40 and 5W40.
Do you guys have any recommendations here? (I am probably going to use whatever oil goes in the SRT8 in my hot-rodded '94 Caprice wagon--it's making power close to the SRT8 and I suspect that the factory-specified 5W30 might not be the best choice for it at this point.) Thanks!
