Just wanted to share something I had learned. If you are having to change a 3 bolt starter on a ford with a 4.6 or 5.4 try removing the starter solenoid first. This way you can get access to the top bolt with just a short extension and a wobble joint. Then put the new starter on without the solenoid and reattach it after the top bolts are installed.
