Originally Posted By: JOD
Originally Posted By: ZeeOSix
D+ will be dome end bypass valve setup. If a base end bypass valve is an important factor, then go for the Motorcraft. Most people don't sweat the location of the bypass valve. If it was that important, all filters would have base end bypass valves.
I don't think it's really an option, at least for filters which will fit on Fords. There isn't a single non-Motorcraft/Ford filter which is an 820S replacement with a base-end bypass, and that's not an accident. If you search the interwebs, it seems to be a patent enforcement issue more than anything else.
FYI ... there are some Motorcraft oil filters that do not have a base end bypass valve, but instead a dome end bypass valve. So just because it's a Motorcraft filter doesn't automatically mean it has a base end bypass. Example:
http://www.bobistheoilguy.com/forums/ubb...446#Post1521446
A base end bypass valve is something Ford likes ... probably because of the orientation of the filter on most of their engines.
Why would that matter? If unfiltered oil is washing over the media, I can't imagine orientation making much of a difference--but maybe I'm not visualizing this correctly (entirely possible).
Most Ford engines at one time mounted the oil filter with the base end typically pointing up to some degree. Ford's theory and the reason they liked a base end bypass is because debris and sediment could collect at the dome end (bottom end in this case) of the filter when the engine was turned off, and debris could possibly be swept thought the bypass valve on initial cold start-up.
Who was that rude noob that always talked cockamamie about "top end" bypass valves?
