Car is overheating when AC is on in stop and go traffic. With warmer temps right around the corner I need to fix this ASAP. I checked the relays and fuses and they are fine. Anyone with info on this car? I've done some searching any havent found the common problem. Guessing I need to test at the connector to see if the fan is getting any juice. If so the fan motor must be burnt out....correct?
