Originally Posted By: cchilb
I run about 80% on the highway and will run by the oil monitor which will give me about 9000 to 10000 miles on a oil change. Looking at 4 oils. The Quaker State for 20.50, Mobil One for 26.50 at wal mart or the Honda or Toyota at about 30.00 at the dealer. I use PureOne Oil Filters. I traded a 2006 Accord in with 200000 miles on it that I ran Mobil One 5w20 8000 mile oil changes 0 problems. I want the best protection and best fuel economy.
well those are somewhat opposing goals.. The oil that will provide best MPG will not provide the best protection. However the engine will most likely outlast everything else with any modern oil.(thats changed regularly.)
0w20 oils I feel are top tier in no particular order and that I can find locally within a 5-10min drive.
M1, toyota, subaru, honda, redline,
other oils that are avail and would be ok if you can get a good deal on them. (ie qt)
O'riellys syn,valvoline,NAPA syn
This will vary by location.. also alot of the less known oils are really good such as Eneos,Motul, Elf
