Originally Posted By: mene
hello Shark, nice to see somebody with a decent amount of miles in an engine. Did you take the head out to check or used a bore camera?, Is it misfiring in the damaged cylinder? I'm asking because in one of our cars even using synthetic oil the valve stem seals had to be replaced every 100K miles or thereabouts, granted not a Honda but a Mitsubishi, when it was at around 300K miles it used 1qt. every 1K miles or so and when I replaced the seals dropped down to about a quart every 4K, a big drop. So my point is that perhaps you can claw back some or perhaps most of that oil use from new valve seals, that amount of oil consumed in just one cylinder must cause a lot of vibration an a totally fouled plug in very few miles from my experience.
Around 280,000 I took the head off, had the head decked, changed the valve seals, lapped the valves. That is when I got to see the score in the cylinder, there were two, you could stick your finger nail into them.
So far my engine seems to be burning the 15w40 up faster than it burned up 5w30. That doesn't make sense.
