I drive about 60k per year. 90% highway driving.
Schaeffer's 10W30 SYN BLEND 7000.
Oil had 16,927 miles when last changed.This is the second Analysis done at Schaeffer's oil Lab. Mixture of Summer and Winter driving. This 2005 Chevy Aveo with 1.6 ltr engine has 57,761 miles. Two PureOne oil filters were used, second PureOne changed half way thru oil change with no make up oil was added. Air filter {Fram}was changed at 5000 miles into this oil change. Air filter now has about 12K miles on it. Oldest report is on left - newest on right.
Silicon {Dirt, sand} High. Oil should be changed. Resample at normal interval to establish trends.
[ January 13, 2006, 10:30 PM: Message edited by: 59 Vetteman ]
====================================code:
Miles on unit 40,480----57,761
Miles on oil 15,400----16,927
Wear Metals PPM
Copper 13---- 10 normal 0 - 40 ppm
Iron 29----- 99 normal 0 - 100 ppm
Chromium 2----- 4 normal 0 - 40 ppm
Aluminum 7---- 10 normal 0 - 40 ppm
Lead 2----- 3 normal 0 - 50 ppm
Additives PPM
Molybdenum 324----- 345 normal
Phosphorus 1005----1079 normal
Zinc 1167----- 1236 normal
Magnesium 10------ 16 normal
Calcium 3061----- 3232 normal
Contaminants
% antifreeze 0---- 0 normal
Fuel Dilution N---- N normal
% H20 .0------- .0 normal
Silicon 19--- 24 normal / Abnormal
Oil Properties
Viscosity 9.70---- 10.26 normal for 30W 9.30 - 12.49
SAE ISO 30 W 30 W normal
Sulfur 7---- 23 normal
Oxidation 12---- 27 normal
Nitration 30---- 41 normal
