Originally Posted By: ZeeOSix
Originally Posted By: Donald
What caused the spreading of the pleats? New that way or from use? Remember this filter is under vacuum not pressure.
I only see one spread pleat ... and it looks like it was made that way. Look at where the pleats are glued into the end cap. It was glued in already spread out.
I think he's referring to the first pic showing the tight pleats on one side and the 'spreading' on the other.
Probably why there is a piece of string.
I only see one pleat that is really spread open ... that's in the 3rd picture. Like I said before, look at where the media is glued into the end cap. It was obviously glued in spread out at the factory. Probably the same for the other pleats that are more open than the other.
Yes, the sting is probably used to help hold the media in place during the end cap gluing process, and I don't think that will result in perfectly spaced pleats. Pretty common to see.
I see what you're saying. I was joking regarding the string 'holding it together' during operation.
