When I had a 2009 Corolla for two and a half years, I used Mobil 1 AFE 0W-20. If I knew about TGMO 0W-20 at the time, I would use the TGMO 0W-20 in hindsight.
There is absolutely no need to use Mobil 1 in new Toyotas while there is a very good synthetic oil (TGMO), which is specifically made for new Toyotas, ensuring a generous amount of ZDDP and moly, which is crucial for valvetrain-wear control, as well as magnesiumfree formulation, which eliminates concerns about corrosive-wear damage to metal parts. It's cheap, of high quality, and readily available in Toyota dealers. There is no reason to experiment with Mobil 1, Valvoline Synpower, or any other 0W-20 if you own a newer Toyota.
Regarding OCIs, my 1985 Corolla owner's manual specifies 10k OCIs on API SF dino oil. Apart from a generous amount of ZDDP, API SF was a somewhat poorly formulated oil, probably with little protection against acidity (little TBN retention). I think there is minimal concern for 10k OCIs with API SN oil, especially with a synthetic oil. At the end of the day, no matter what kind of oil you use, you will probably be OK, likely even with a dino. There is little chance that any API SN synthetic will fail in 10k miles in any Toyota engine. Therefore, rest assured with any SN synthetic. As for the choice of the brand, at the present moment, I would definitely pick up TGMO from the information available out there and also simply for convenience, peace of mind, and OEM certification, not to say that it's definitely the best 0W-20 out there, which is something that's always hard to judge and prove.
