The tranny seems to operate fine other than this two speed 4th gear thing. 1st-3rd is fine. It started as soon as I switched the atf out with M1 syn.
That really does sound like the transmission is expecting to have a friction-modified fluid and the TCC is just grabbing instead of smoothly engaging or going into a partial-lock mode. Modern (post 1990) transmissions do very complicated things with the TC clutch, locking it partway in some gears, and the slowly locking it as speed builds in final drive so it almost acts like a continuously-variable tranny. To do that most of them use friction-modified fluid to keep the TC clutch from grabbing or chattering. (like Mopar ATF+ 4, but there are many others).
I see... Thanks for the breakdown. Would you recommend going to a standard Dex III (recommended fill) or a M/V forumla, may have more friction modifiers in it to help aid the TC to engage properly?
If the owner's manual calls specifically for Dex III then that's what I'd try. Problem is, most fluids today are Dex V and claim backward compatibility to Dex III, but there are some subtle differences (Dex V is slightly lower viscosity, IIRC). But I think you can still find true Dex III.
Its also possible that you had some internal failure coincidental to changing the fluid, or if its a computer-controlled transmission it may be in the re-learning process as others have mentioned. What manufacturer and model/type is the tranny in this vehicle? Some googling makes it look likely that its a ZF of some flavor.
Alright, I'll go for the standard Dex 3 and see what happens... I doubt it was a coincidental failure, the trannys in these are pretty tough (ZF trans btw). Most last 200k+ without issue. I appreciate your insights though! I'll let you guys know what happens.
