I have the Q industries MV-50. While it is by far the best 12 volt compressor I have owned/used, I do not think that says too much.
It pulls 16 to 18 amps, connects right to the battery with some alligator clips, and I don't think it likes voltages over 13.5, so running the engine whilst inflating might be a no no.
The Air filter is a good idea, which makes it quieter too, but do take a razor and remove all the extra plastic flashing from the housing mold to reduce restriction.
I do not really like the part which connects to the Schrader valve as I use it mostly to inflate my suspension helper air bags, and If I pump them up to 50, they are down to 35 by the time I unscrew the connector.
I wanted to change hoses but the fittings are non standard, and I could not unthread the original, so I just left it as it came from the box.
Harbor freight has a similar Viair knock off that other report works well.
