Originally Posted By: Wilhelm_D
Originally Posted By: CapriRacer
I explain the process used to qualify tires for new vehicles here:
http://www.barrystiretech.com/oetires.html
Short version: The vehicle manufacturer decides the speed rating.
Short version, cheap is good, cheaper is better....
Sorry, but, No. The vehicle engineers set the specs first (and that would include the speed rating) and the purchasing agents negotiate the price later. Needless to say, with millions of dollars on the line, the purchasing agents at the vehicle manufacturers are really good at getting the rock-bottom price. But all the tire manufacturers are working off the same specs. In other words, the speed rating is NOT part of the price negotiation!
......As a consultant to major automobile manufacturers in the US over three decades I can assure folks that a 2006 Elantra did not require H-rated tires, and that when Hyundai made the decision to use them cost was the single largest criterion in their decision. The second biggest criterion was ride.......
I appreciate that 30 years of consulting may give one a level of expertise, but I have more years in and they were all involved with tires - and I spent 5 years in Detroit, directly involved in the whole tire qualification process.
Now let me parse this out:
"Requires" That might mean many things.
There's a law? No
There's an engineering standard that has to be met? Maybe!
If the top speed of the vehicle is close to 118 mph, then it might sense to go up a step. Is that a "requirement"?
From the point of view of supplying the tire to the assembly plant - Yes!
But what about buying replacement tires?
Again, there is no law. As a matter of fact, there is very little regulation in the US concerning replacement tires what can be applied to vehicles. You can put on any size/speed rating/brand you like. If you've seen some of these "LowRiders", you'll know what I mean.
But I don’t think anyone is arguing that it is REQUIRED. I think we are arguing about what is advisable.
…..It is the same reason tire inflation pressures recommended are usually too low. The automobile manufacturer wants to make money selling cars, and it accomplishes that by reducing costs in manufacturing and by providing something people would like to buy. Most people want a nice ride…..
To some extent I agree, but the issue of low inflation pressure goes to load carrying capacity – and there are other ways of skinning this cat. Larger tire size for example.
Cars produced since about the 1980’s have been pretty good when it comes to the tire load thing. SUV and pickup trucks – not so much.
But that has been fixed. Not only have cars increased their size, they’ve also increased the speed ratings. This results in a safer vehicle.
This leads me to the opinion that H speed rated tires should be the minimum.
That seems to indicate some confusion as to what a speed rating actually is.
Are you suggesting that an S or T rated tire could be driven at a high enough speed long enough to fail in a normally loaded Hyundai Elantra assuming proper tire inflation?.........[/quote]
No, I am not confused. Earlier I referred to failures in S and T rated tires- and that is what is driving that statement.
I am NOT saying the failures are the result of the speed. I am saying that what is needed to make a tire pass an H speed rating results in a tire much, much more durable – that is more resistant to failure.
Sorry, but speed ratings are pretty much tied to the use of fabric overlays (of the belt) commonly known as cap plies.
The primary cause of failure..……
I ‘ve been at this for over an hour and a half. I’ve deleted the next part as it is full of mis-information and there is no point in repeating it. The original post for this thread isn’t being addressed any more – and we should return to it.
……The speed rating has nothing to do with durability. It has to do with the ability of the tire to operate at a given speed using a standard methodology…..
Perhaps the problem is one of terminology. I use the term “durability” in the classical sense of performing without failure. Needless to say, I am excluding failures caused by external sources, such as punctures, cut, and impacts – what is typically called “Road Hazards”.
Clearly, any speed rating test IS a measure of a tire’s resistance to the affects of speed – and that’s durability.
I am now going to try to wrap up this conversation with a few remarks.
The original posting in this thread was about what Tire Rack said about other tire shops and how those shops approach the speed rating issue.
Summary:
There isn’t any law or other such requirement that tires have to have the speed rating that came originally on the car. However, there are some legal liabilities that would surface if a tire shop would do so – so it is understandable if a tire shop was reluctant to.
There is also some technical and safety reasons why putting on a lower speed rating might not be advisable.
