So I am wondering If I can use a Oil extractor like this http://www.amazon.com/Trac-Dynamics-Oil-Extractor-liter/dp/B0000BYO97 to remove ATF fluid so i can re-fill it with new fluid.
as I understand it Getting the pan dropped and filter changed only removes some of the fluid and the filter is usually clean unless something is wrong. So im wondering If i can just use an extractor to get as much fluid out as an alternative.
last year it cost me 90 bucks to have my pan dropped and filter changed on my Jeeps automatic transmission, I could buy the extractor and then be able to afford the ATF fluid alot more often then having a shop do the pan drop. I could this every 10k miles instead of maybe 30k miles for a pan drop (30k is whats recommended in owners manual)
I don't have the time or ability with the tools i have at home to do the pan drop myself. i would need to remove my transfer case skid plates and then need something to support my T-case ect....
pumping out a gallon of atf fluid and refilling it with fresh fluid every year would be so much simpler. Then maybe have the filter changed every 60-80k instead of 30k?
Im trying to justify buying an oil extractor to have with all the machines I have around and if I could do this and use it to change out my diff fluid too then it would be worth buying.
call me cheap or lazy but would this be a good idea?
