Same oil for the life of the car, Mobil 1, 5w40. 0w40 is just now showing up on store shelves here, and I will go to it at the next oil change.
Ah, that could very well be!quote:
Originally posted by haley10:
Looks like you were previously running the old Tri-Synthetic formula, while the latest is the M1 with SuperSyn formula.
Something is wrong. No way M1 5W-40 can be beaten to a low 30 wt. or high 20 wt.quote:
[qb] Same oil for the life of the car, Mobil 1, 5w40. 0w40 is just now showing up on store shelves here, and I will go to it at the next oil change.Something is wrong. No way M1 5W-40 can be beaten to a low 30 wt. or high 20 wt.
Well, I take that back. The turbo must be really beatin' the crap out of the oil.
DOH! My bad, I have been using 5w30 (not 5w40)since the first oil change on the car.quote:
Please clarify.
I autocross monthly, but I did last year as well. The latest VW requirements say 0w40, but the manual says 5w30 is acceptable. VW has gone to 0w40 to help out with their "sludge" problem in the turbo. I've been using up my cache of 5w30 5-qt jugs in the meantime. 0w40 next time around though.quote:
I'm not a VW guy, but the Copper is up significantly and the lead slightly, have you had your foot in it a bit harder on this run?? Is 5W-30 recommended for this engine or is there alternative recommendations.
