Read a lot about Redline products since coming onto this forum. When I got some SL-1 fuel system cleaner I got some Water Wetter on impulse since it was also Redline and close by on the shelf. However, when I read on here (and then search the whole www) I read that it sometimes has a bad reaction with some antifreeze. Have no idea what is in the new old car so I won't just add it in to that.
I do plan at some point to drain the cooling system and put in some new coolant.
Here's what I was thinking. If I drain the system, put in the Water Wetter with distilled water, and then run it for the summer. Then when I have time in the fall I could change the hoses, drain the system again, and put in the antifreeze of my choice. Of course, it I have time now I could drain, replace, water wetter and then just drain and antifreeze in the fall.
Any pro's or con's to one way or the other? Should I just chunk the Water Wetter and not risk it sludging my system?
