In the US an oil mix of 50:1 is specified, below the equator things suddenly change to 25:1. You can check it out here
http://www.maruyama-us.com/uploadedFiles...s/BL3100%20.pdf
and here
http://www.poweruplawncare.com.au/maruyama/manuals/bl3100.pdf
Then there's Tanaka's instructions on the issue:
Fuel
• Always use branded 89 octane unleaded gasoline.
• Use Tanaka two-cycle oil or a quality two-cycle oil at mixing ratio of 25-50:1 (Gasoline (A) : Oil (B)), only for the
state of California at 50: 1.
• Never use multi-grade oil (10 W/30) or waste oil.
• Always mix fuel and oil in a separate clean container.
Are any of you using these uber rich mixtures? Have you had success? Problems?
I have been using a 40:1 mix under the theory of playing it safe, but now I wonder if I shouldn't just go hog wild. After all it will still be within the manufacturer's recommendations someplace.
and here
Fuel
