Here is a list of the tests and acceptance limits for the LB classification, limits are in perenthesis. I believe they meet most of the specs but aren't certified maybe because their market.
I had a heck of a time keeping it somewhat lined up and I type with two fingers
Properties and ASTM Test Method
Worked Penetration D 217 (220 to 340)
Dropping Point (°C D 556 or D 226 (150)
Four Ball
Wear (mm) max D 2265(NA)
Four Ball EP D 2596(NA)
LWI (kg) min
Weld Point (kg) min (200)
Elastomer Compatibility D 4289
CR, Volume Change (%) (0to 30)
CR, Hardness Change (0 to -10)
NBR-1, Volume Change (%)(NA)
NBR-1, Hardness Change (NA)
Oil Separation (%) max D 1742 (10)
Rust, max D 1743 (Pass)
Fretting Protection (mg loss) D 4170 (10)
Low Temperature
Torque at 40°C (N-m) D 4693 (15.5)
Water Resistance at 80°C
(%) max D 1264 (15)
High Temperature Life
(h) min D 3527 (40)
Leakage Tendency (g)
max D 4290 (24)
