Well, I'm going to give this a try and see what sort of a difference there will be afterwards. My Grand Marquis knocks slightly with 91 AKI under heavy load and it's even worse with 87. 80% of my driving is highway (using cruise control), but I reckon the previous owner's trips consisted mostly of short stop-and-go trips.
I'm considering filling up a sprayer bottle with hot water, and inducing it slowly through the brake booster vacuum line whilst operating the throttle by hand (2-3k rpm) with the engine at operating temperature. But I was wondering if it would be more effective if I was to spray it straight into the throttle body?
On another note, I will be using Liqui-Moly Pro-Line Engine Flush when I change my oil next week. Should I just skip this and just flush the engine instead? Wondering if cleaner ring packs would help partially solve the problem. Thanks!
