In the shocker of the year, I have traded in my 2004 Nissan Titan for a 2006 Kia Spectra 5. I'm looking for oil recommendations in the beast. I haven't found that many UOA's on Kia vehicles at all.
Engine is a Hyundai 2.0 "Beta II" with variable valve timing, or CVVT as they call it. It has 138HP.
Manufacturer's recommendations are all over the place. The factory service manual is actually available ONLINE (!!!!) at the following address:
http://msw.kiausa.com/viewer/default.asp?group=shop
Choose the options for Spectra[LD], 2006, and 2.0 to get the service manual for my car.
In there, it mentions using an oil of API SH or above and ILSAC GF-1. It seems to state that 10w30 is OK up to 40C, but that 10w40 and 15w40 should be used for temps above that (we do occasionally exceed 40C/102F here in the summertime). 5w30 is stated to be only for use in temps below 10C.
Wow. This is the kind of recommendations most manufacturers made up until the early 80s, but haven't been seen in quite some time.
The owner's manual seems to paint a different picture. It gives the specs as SJ,SL or above, ILSAC GF-3 or above. 10w30 is ok from -5 to 120F, which would certainly encompass any conditions I am likely to encounter here in Texas. 5w20 and 5w30 are allowed from the bottom of the scale to the top. This is a big departure from what's in the factory service manual.
Additionally the owner's manual says: "For better fuel economy, it is recommended to to use the engine oil of a viscosity grade SAE 5w20,5w30 (API SJ,SL / ILSAC GF-3). However, the engine oil is not available in your country, select the proper engine oil using the engine oil viscosity chart. Now while I would certainly like to get better mileage, I would also like to get the lowest wear readings...
Regardless, it seems like that for 97% of the time around here, both sources would be ok with 10w30. And, being able to use SJ oils would probably allow for usage of CI-4+ diesel oils, which have much higher ZDDP levels. However, are any of these oils GF-3?
I'm probably going to have to change every 3,000 to stay in warranty compliance, so probably dino is in order, unfortunately. The severe service schedule is 3 mos/3,000 miles. I do lots of short trips and frequent driving above 90F so I definitely qualify.
Any recommendations...let's hear em. Also interested in filter recommendations.
