Originally Posted By: cp3
Originally Posted By: JustinH
My 03 Ion has a fuel filter in-line if that helps.
Where is it? Didn't have it up on the ramps this weekend but I did roll around it a bit on the creeper and couldn't find anything.
The filter is mounted horizontally, not towards the front and rear like on most vehicles.
It is right near the gas tank. If you crawl under the back side of the car, you can see high pressure hoses with quick disconnect fittings on them, the filter is attached to that.
The quick disconnect fittings are GREAT, and come off with your fingers. When you get those off, you need to use a disconnect tool to actually get the filter off the line which was a challenge for me. I've done MANY cars with this style filter (fords), and it is usually a 2 minute affair, but the saturn was very tough, due to something being bent in the locking mechanism of the filter that someone else had put on.
The entire job "SHOULD" be about a ten minute affair.
