I've got a kilowatt Zerostart tank heater plumbed in to the lowest spot of the coolant loop on the Golf and it's wonderful. Set it for 3 hours before I leave in the morning on a heavy duty appliance timer in the garage and the car fires right up without issue and I get nearly instant heat. Really boost fuel economy for my 9 mile commute in the winter.
FWIW, this one operates solely by thermosiphon and has no pump or check valve. If you take care to install it at the lowest point in the coolant loop without any hose sags it works perfectly with zero moving parts.
