Hi guys, I just purchaced a used toyota corrola for my daughter, when I got it home I wanted to run some fuel injector cleaner thru the system so I poured a can of seafoam in the gas, its a smallish tank and I used about 3/4 of the bottle.. After about 10 minutes of highway driving the engine light came on, when I got home I pulled the code and it was a bank 1 o2 sensor fault. Do you suppose that the solvent in the seafoam gave the sensor a bogus reading? It seems like that is the case, what are your opinions? Thanks in advance.
