Originally Posted By: Craig in Canada
If EOD (end of driveway) plow pile is a big thing in your area, you'll probably want a two-stage. When you have a large snowfall what kind of snow is it - fluffy or heavy?
This is the conundrum of my area. Our typical snowfall amount doesn't warrant a two stage (with exceptions, of course, both in terms of individual storms and heavy snowfall years) but any heavy snowfall we get is always some kind of Colorado low, or Nor'easter or some other event which dumps snow, ice pellets, freezing rain and rain on us. This is then immediately followed by the salters, then the plows. We have virtually NEVER received a deep, fluffy snowfall like many other areas you'll receive advice from.
Same here...I found the typical smaller single stages good for a lighter snow, but a good heavy, wet snow or sleet; and they really struggle compared to a two stage.
Now the bigger tractor-mounted single stages are pretty good...I've seen quite a few JD versions that work well, and as good as any two stage in moderate snow. But a true two stage is the only way to go in heavy deep snow...and that's mainly because these usually have a lot more HP running them.
