Originally Posted By: Steve S
Originally Posted By: milwaukee
Steve,
A 5w-30 is like syrup when cold and water when hot/operating temp? Syrup does NOT "thicken" to water. The syrup turns into water i.e. it becomes thinner. What is so difficult? The numbers 5w and 30 are values NOT thickness ratings.
Hot 30 wt is thicker than hot 5wt what is the problem with understanding that? at any temperature 30 is thicker than 5. 5w-30 oil has to thicken to equal a 30 wt when hot otherwise it will be a 5w. I am not debating that heat thins out a straight wt oil I knew that 45 years ago.
At no point does a multigrade oil increase in viscosity due to increased heat. Period. It simply does not thin as much, because the VII's expand and make it have more viscosity than it otherwise would.
Steve,
